Previous in Forum: wealth without work   Next in Forum: Equation to Raise 1 kg of Water 1 Degree C
13 comments
Good Answers: 53
Have a look, not a big challange.
11/11/2006 7:28 AM
Two balls mass of 100 kg each are tied with string length of 1000 km. A force gauge is hanged at the distance of 1001 km in space. Mass of string can be considered zero for practical purpose.
Now these tied balls are fixed on the force gauge in such a way that one ball is very close to earth (1 km ), where as another one is just close to force gauge.
Note that, lower ball is not connected with force gauge directly . It is connected with upper ball and upper ball is connected with gauge.
My question is "what will be value shown by force gauge"
What should be considered the Height of Center of gravity?
Should we consider two balls as a one article as it is connected with string?
Or we should calculate both the balls separate and add them.
I tried both the way can calculation doesn't match.
What is the right way?
Re: Have a look, not a big challange.
11/11/2006 3:47 PM
Use F = G(m1m2)/r2 for each ball and add the results.
Using G=6.67x10-11, and r(earth)=6.335x106, I get
F (lower ball)= 993N(?!), F (upper ball)= 741N, F (total)= 1,734N
The figures are moot, but the principle is, I believe, correct. The 'string' transfers the force from the lower ball, via the upper ball, to the force sensor (which is presumably fixed to a sky-hook).
11/11/2006 4:23 PM
Sorry, forgot to say I used 6×1024 kg for the mass of the earth (m1).
r(earth) =6.335x106 m, G =6.67x10-11 Nm2kg-2.
Also forgot to subject myself to my own rules about specifying the units !
Good Answers: 53
11/12/2006 1:04 AM
alrite
Good Answers: 53
11/12/2006 1:08 AM
Read "weight" as "mass" in next post post.
Good Answers: 53
11/11/2006 11:03 PM
Jhon My question is why not alternate way?
what if I take the CG at the distance of 1000/2+1KM (exact at the centre of string) and combind both the weight. Which one is right way?and why?
11/12/2006 5:59 AM
You can't just combine the masses this way, because the gravitational force obeys an inverse square law. It would only work if the string was horizontal, i.e. both masses were at the same distance from the centre of the earth.
(1/r2) + (1/(a+r)2) ≠ 2 x (1/([a/2]+r)2)
11/11/2006 7:49 PM
Why should I care?
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Good Answers: 53
11/12/2006 12:58 AM
who suffers?
Good Answers: 75
11/12/2006 6:13 AM
Consider the situation blow
Where a point m is effected by the gravity of a point mass p. In that case the object would experience a force proportional to the inverse of the square of the distance such that
F = (m + p)s-2
Now if we consider the line Q-R and consider it is made up of multiple point masses Δm taking note that the direction of the forces is not the same and needs to be accounted for then that the force would be
F = ΣΔmS-2
And if the increments were infinitely small the force would be
F=∫ms-2 ds
Which may not be the equivalent of looking at the force that would be exerted by a point mass through the center of gravity. Therefore the correct answer is the one that deals with the two masses separately and adds them together not the one that uses the center of gravity.
Good Answers: 53
11/12/2006 6:35 AM
If that is the case then what if I make the string that is reasonably thick, say equal diameter to ball and connected rigid to both balls. Now its huge long rod,
Will you still apply integration? Or will take the CG and combined mass?
If you apply integration then my question is why not in the case of two huge. Sphere for example two planets.
Good Answers: 75
11/12/2006 6:49 AM
You need to apply the integration regardless. The only time you could use the center of gravity is when the difference between the height of the tow ends is zero or negligible. Try doing it for a string 1000m long rather than 1000Km and you will see that you could probably get away with using the CG.
11/12/2006 9:59 AM
Shouldn't your 1st equation be:
F = G(m x p)s-2
or have I misinterpreted your diagram?
Good Answers: 75
11/12/2006 10:46 AM
Your are absolutely correct. Sorry I wasn't paying close enough attention to what I was writing.
Register to Reply 13 comments
BrainWave (1); JohnDG (4); masu (3); rakesh_semwal (5)
You might be interested in: Force and Load Sensors, Balls and Sphere Shapes
