Previous in Forum: Calculating Maximum Nitrogen Flow   Next in Forum: MAWP for Spherical Tank
HELP
03/19/2009 3:15 AM
How can i calculate Hydrotest pressure for SA 106 Gr-B pipe of 18" NB and schedule 120 .?
I have some data- 18 " NB pipe OD - 18 "
As per 120 Schedule Thickness - 34.92 mm.
Pl. help
Good Answers: 103
Re: HELP
03/19/2009 4:04 AM
Are you under ASME codes ? For that you may refer the ASME standards say B31 series as applicable
Re: HELP
03/19/2009 5:33 AM
From ASME B 31.3 I COULD NOT FOUND ANY FORMULA FOR HYDROTEST CALCULATION.
PL. HELP.
Good Answers: 103
Re: HELP
03/19/2009 8:44 AM
This is a link currently available with me, for DN 450 (you are DN 457.2 but the values are almost matching)
the pressure rating at different temp is given
http://www.matthewdavis.com.au/downloads/pds_Pipe_Pressure-Temp_Data_Sheet_Pg2.pdf
check the standards, the hydrotest (if I remember, is 1.5 times the rated pressure if not covered specifically). But not in business for this area (Pressure vessels) for a long long time
Good Answers: 51
Re: HELP
03/19/2009 9:39 PM
It depends on what code the piping system was designed and built to.
For instance, with the popular ASME B31.3 (2008) paragraph 345.4.2
When the design temperature is greater than the test temperature -
PT = 1.5(P)(Rr)
Where:
  • P = internal design gage pressure
  • PT = minimum test gage pressure
  • Rr = ratio of ST/S for pipe or components without established ratings, but shall not exceed 6.5 OR = ratio of the component pressure rating at the test temperature to the component pressure rating at the component design temperature for components with established ratings, but shall not exceed 6.5
  • S = allowable stress value at component design
    temperature (see Table A-1)
  • ST = allowable stress value at test temperature
A little knowledge is a dangerous thing.
Anonymous Poster (1); sb (2); XMech (1)
