Previous in Forum: MCCB Calculations   Next in Forum: 600mm wide ladder type cable tray loading & support
What is a Carrier Current Controller?
03/19/2009 11:17 PM
Anyone know what a carrier current controller is? it is located beside my fuse panel and looks original....about 40 years old. it also has 3-wire connection load, line and common.
Good Answers: 247
Re: carrier current controller
03/20/2009 12:33 AM
It is probably intended to shut off your water heater under high load conditions. Power companies will usually give you a better rate if you let them install one of these.
