Previous in Forum: DC to DC converter   Next in Forum: MCCB Trip Issue
11 comments
grid resistance & pit resistance
03/20/2009 3:48 AM
hi,
I want to know what are the resistance values allowed as per different standards for grid earth resistance and pit resistance.
and does any standard say to take grid and pit resistance.
Re: grid resistance & pit resistance
03/20/2009 5:11 AM
IS <1 ohm IEEE <5 ohm. here are you locating. Get registered first.
BNDas
10/07/2010 2:39 AM
Dear Sir,
I have a problem In my 220kV Substation .Grid earth resistance is less than 1 & individual earth pit resistance(disscunnected from grid ) is more than 2 ohm. Is it ok
03/20/2009 7:16 AM
let us consider 3 pit resistance is
  1. P1=X
  2. P2=Y
  3. P3=Z
So Total Grid Resistence Will Be
Grid=X+Y+Z
So total grid resistence should be less than 5
So pits resistence should be as sothat there all sum should be less than 5
03/20/2009 7:22 AM
Yes mr pandit! you are wrong! Resistances are in parallel. not in series as you answered.
BNDas
03/20/2009 7:37 AM
Dear Sir
As i know that in grid all resistence should be in series so if all will in parrell then if valu of pit resitence is low then Grid valu will be large
GRID RESIANCE =1/X+1/Y+1/Z for parell restence if X,Y,Z will be large then only grid resitence will be low which is not possible if I wrong kindly make me clear Thanks
03/20/2009 7:40 AM
Do you have IEEE 80?, go through pl.
BNDas
03/20/2009 8:24 AM
Dear sir
i check all through IEEE 80 but not get satisfactory answer kindly make it clear sir i will be thankfull to you for this
03/21/2009 12:45 AM
sir,
as i know If a grid is made of lets say 4 nos. of earth pits.
A= W+X+Y+Z
Total Grid resistacne should be 1/A = 1/x+1/Y+1/z+1/W
My question is that do i need to measure the individual earth pit resistance while disconnected from the grid.
or i just have to measure the individual earth resistance in connected condition.
I simply put the word pit resistance and grid resistance
Pit resistance = resistance measured of individual earth pit while disconnected from grid.
Grid resistance = resistance measured of individual earth pit while connected with grid.
As i understand grid resistance is always going to be less than pit resistance.
Do any standard ask specificaly to take grid and pit resistance separately. and do they have specific limits for that.
03/21/2009 3:31 AM
Dear all
canany one explain what is advantege to connect earth pit in parrel and what will be the disadvantege to connct in series
06/13/2009 5:09 AM
acceptable grid and earthpit resistance values
01/29/2014 12:49 AM
As per OISD -149 Acceptable grid resistance value is <1.0 ohm
earthpit without grid <2.0 ohms
earthpit for structure <2.0 ohms
earthpit for equipments < 4.0 ohms
Anonymous Poster (1); biswanath.das (3); dineshpandit80 (4); dvkodge (1); mmdqadir (1); tank_sandeep (1)
