Please suggest me an equivalent indian standard for DIN 1025 Part 2 IPB 550
There is no indian Supplier who supplies DIN 1025 Part 2 IPB 550. If there is no equivalent indian standard then,suggest how to manufacture it in India
Hi dinakarj,
DIN 1025 Part 2 IPB 550 corresponds to hot rolled Steel sections for special purposes. Basic steels are cast as killed steel. There is no straight equivalent in IS. These are un-alloyed steel similar to St 37-2 with carbon per cent = 0.17 max., Mn = 0.4 to 1.40 %, P & S = 0.50 max & Tensile Strength = 340- 470 N / mm 2. You may now ask Mukand or Issal or Sunflag or Usha Martin or Vardhman Steel mill to develop your requirements. Hope this helps you. Rangasamy
Let noble thoughts come to us from every side.
Thank you very much for your reply.I am from Coimbatore working in Essar steels surat.For the Standard DIN 1025 -Part 2 IPB 550 my customer is asking approval for fabricating with IS 2062 for web and IS 8500 for flange.What is your opinion??
Hi dinakarj, DIN 1025- Part 2 IPB 550 material is good to fabricate with IS 2062 & IS 8500 since both these two specifications also come under the category of low carbon steel only. However, before giving green signal for bulk or series production, please ask your customer to try out on a smaller lot. Good Luck. Rangasamy
Thank you very much.Is there any specific reason for choosing different material for Web and another different material for flange from my customer because my required I section is of a single material St 37.2.Please give your opinion.
Hi dinakarj, Based on application or the end use, the Designer chooses the material. If you want to know the reasons, you have to only ask your customer. I suggest that you may arrange to get a copy of IS standard which will clear your doubts. Rangasamy
