Previous in Forum: out put of panel   Next in Forum: Bearings clearances limits
Alternate for Solenoid Coils
03/22/2009 1:36 AM
Is there any alternate, cheaper system for electrical solenoid coils which can produce a force of ~12 Kg and distance of ~6MM? If it is available please explain the sytem
Good Answers: 53
Re: Alternate for Solenoid Coils
03/22/2009 5:30 AM
Solenoid are not only cheaper but they offer leaner motion with out too much of paraphernalia.they are simple and easy to use. Theoretically there can be many ways of eliminating solenoid. But not at the low cost.
Good Answers: 53
03/22/2009 9:48 AM
Manual actuation of the equipment would eliminate the need to purchase those expensive coils.
"If you can't use your head, use your hand."
Good Answers: 54
03/22/2009 11:31 PM
I'm not sure I understand your question, but have you considered using pneumatic cylinders, they're light, fast and cheap (if you happen to have a supply of clean compressed air and a nearby solenoid valve). Check out FESTO, SMC etc.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
03/23/2009 3:36 AM
If the travel distance is any smaller one can consider piezo electric actuators.
Metallic bellows with compressed air or hydraulic force and work as well.
sitapati rao
03/23/2009 8:58 AM
wax motor lots of appliances use them these days mostly to lock the door
03/23/2009 9:31 AM
Typically a solenoid is the cheapest way for an electric current to move something. when large forces are required, frequently a solenoid triggers the release of another, larger force. For your scenario a secondary source (pneumatics, hydraulics) would probably be best.
03/24/2009 5:00 AM
Car door locks often use a motor geared to a thread to produce the linear motion. More parts than a solenoid but mass produced so low cost - or get from a scrap yard.
Decision may depend on whether you want it to stay in both positions, in which case the lock mechanism will save power and heat too.
In my experience solenoids always finish up marginal for power, especially when they get hot.
Register to Reply 7 comments
Ace Boeringa (1); Anonymous Poster (2); ffej (1); JayGeeBSE (1); rakesh_semwal (1); redfred (1)
You might be interested in: Motor Coils, Solenoid Valves, Solenoid Valve Connectors
