Previous in Forum: how can i find guage   Next in Forum: High Cable Currents and Temperatures
Selecting the Right Sensor Range
03/25/2009 12:09 PM
i an doing a project with sensor as a very important device but i dont knw how to select the range of the sensor (in my case : i need to measure light of the vechile high beam or low beam from a distance orf 30 mts. i have decide to use LDR or photo diode) which range shall i go with and the reason too
Re: how to seclet the range of the sensor??
03/25/2009 12:16 PM
I would think some basic work on the optics was the start point e.g what angle are you going to collect light from ?
The other thing I'd be looking at is differential vs absolute?
After that some empirical tests should give some idea of working range.
03/25/2009 5:00 PM
Yep, this is a case where a bit of guess work and a lot of fun playing experimenting and testing are in order. Fortunately there are a limited number of sensors of these type available so its not too confusing, difficult or time-consuming an approach.
I think the lecturer would also agree.
Register to Reply 2 comments
