I once built a nice little fountain / pond thing with some limestone that I grabbed from the foundation of a building that was torn down long ago. That was nearly 10 years ago, and it used a small pump. The gold fish are huge now and cant wait to get back outside.
...I know a guy who wants to build a water feature on a larger scale.
He has a perfectly great pool pump that is top notch, but I wonder if it's overkill.. or worse.. doomed to mechanical failure.
but then I wonder if brackish water that will be the source of the water will foul the nifty hydraulic pump? It's a WhisperFlo WF-4
and with a head of only about 12-15 feet it might be pumping out nearly 120 GPM!
that seems like an awful lot, but it might work with the scale of the project.
Obviously the intake would be filtered for particulate etc, but the source is a very large pond.
I'm trying to scale the pro's and cons of a traditional submersible pump.
I think the 1HP pump could be cut in half, and the filtering would be easier on regular pump?
thoughts appreciated!
