Previous in Forum: Producing a Generator With a Car Engine   Next in Forum: mechancal engineering need help
Ball Screws: Back Calculating Torque
11/14/2006 9:29 AM
I have a ball nut that needs to lift a 400 lb load. I know the speed is 3950 rpm. How do I back calculate to figure out the torque the motor is supplying at that speed and load? I have all the ball screw data I need, I just can't get the units to work out. Is there any literature out there on ball screws (preferably a text book)? Most of the information I have found has been on power screws, not ball screws or ball nuts. This information seems very hard to find.
Thank You.
Pathfinder Tags: Ball Screws
Re: Ball Screws: Back Calculating Torque
11/14/2006 4:56 PM
Look at a company called Nook Industries
www.nookindustries.com
They could help,Good Luck
Mark
Mark
11/14/2006 6:33 PM
Hi: I supposse you can do an energetic equation; that is; speed of lifting x weight=torque x angular speed.
As you told in your post, you know all the data, so you can calculate the torque.
Regards,
Gabriel
Gabriel, Buenos Aires, Argentina
11/15/2006 12:57 AM
Torque = Force *pitch/(2*pi*eta)
Where eta is the efficiency of the ball screw (take it as 90% if you don't have a better figure). pi = 3.1416.
If pitch is in inches and force is in pounds force then torque is in lb-in.
Ball screws are just very efficient power screws for analysis. Notice that speed does not affect the torque. It does affect the power, though.
Power = torque * N * 2 *pi/(60 *8.79)
where torque is in lb-in, N is in RPM, and power is in Watts. (The figure 8.79 is required for the unit conversion - it really is much easier in metric units)
Greg
11/15/2006 12:03 PM
For back driving torque try to use the simple formula
T=.143 P*L
Where,
p=load (lbs)
L=Screw lead(inch/turn)
11/15/2006 5:48 PM
Go to FAG, Beaver, Saergeant, Shrillo web pages.
11/18/2006 5:36 PM
Remember that there is a rotary to linear work conversion relation.
Hence,
efficiency= (Force x linear distance per revolution)/Torque x 2 x Pi
Pi is there to keep the units pure, i.e., 2 Pi radians/revolution
linear disatnce per revolution = lead of the screw
Keep the units consistent.
The .143 factor is just the reciprocal using an assumed efficiency of 0.90 multiplied by 2 Pi. The assumption is far and appropriately conservative. Efficiency typically will increase slightly w/ speed. However, this is good enough for steady-state, i.e., constant velocity requirements.
For dynamic torque-the torque to accelerate, the inertias of the system need to be evaluated.
See the authors Juvinall & Mott mechanical engineering/design texts.
Register to Reply 6 comments
Anonymous Poster (2); brown (1); Gabriel (1); Humi (1); Mark A Huntington (1)
