I have data sets of about 400 points each that have values of x,y,and
z. I need a charting program that can create a 3 dimensional scatter
plot of these points. I would like to be able to view the plot from
different angles.
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
Check out Scilab- it is open source, similar to Matlab. Also, NIST DataPlot may be able to give you what you are looking for. Both are open source and gratis.
Thanks for the suggestions. After checking all of them plus a few others, I tested http://www.doka.ch/Excel3Dscatterplot.htm. It appears to do what I want. A more complete explanation is available at http://en.wikipedia.org/wiki/3D_projection.
Even though Excel is only a 2D program, you can write macros that will
yield 3D results. I'm also told that Macintosh comes with a piece of
software called Grapher that will also work. Thanks again.
