Hi,
Can anyone help me in showing where do can I get the standard of Minimum Insulation resistance for HV Switchgear. When I work at the factory I used to use " Voltage rating of the measured equipment / 1000 + 1 MOhm" as the minimum insulation resistance of the equipment; now I work at HV Substation ( 70 kV and 150 kV SS ), I don't know what is the right standard of this matter. For 70 kV CT I got 40,000 MOhm, 15 MVA Power transformer Phase to ground at 150 kV bushing even higher than that, it's about 200,000 MOhm with 10.000 Volt Insulation resistance tester.Recently I measured ABB 70 kV Potential transformer, I got at two units from phase R and S about 60,000 MOhm, and phase T only 12,000 MOhm I measured with 10,000 Volt Megger. Insulator has been cleaned properly,because I didn't know what is the minimum resistance allowed to energised this PT, base on my past experience I just put them into sevice. The result is OK untill today. Can anyone help me regarding this matter ? Thank you.
Stanyadji
