We would like to find an economical way to reuse the same Freon by the mean of reclamation. Reclamation is the re-processing and upgrading of a recovered controlled substance through such mechanisms as filtering, drying, distillation and chemical treatment in order to restore the substance to a specified standard of performance.
We are using a refrigeration system known as the Economic Refrigeration Cycle to remove liquid hydrocarbons from the process gas by cooling the process gas after passing through the Chiller. As Freon degraded, the system will be recharged with fresh Freon refrigerant R-134a.
Regards'
Hamad
