Previous in Forum: Home made Electromagnet Project   Next in Forum: Dry Ice as a Power Source
How is Hexavalent Chrome in Coatings / Metals Harmful?
03/29/2009 11:29 PM
Hexavalent chrome in elctrolytic baths, mix in water or air and cause pollution. But how does the hexavalent compounds in coatings affect the environment. Do they mix in air/water.
If not why does the ROHS says the hex chrome in coatings/metals should be less than 1000ppm. Are they indirectly preventing the use of electrolytic bath.
Good Answers: 101
Re: how is hexavalent chrome in coatings/metals harmful.
03/30/2009 2:52 AM
  1. Chromium is a toxic heavy metal that can cause brain damage. It is also a suspected carcinogen.
  2. No.
Good Answers: 243
Re: How is Hexavalent Chrome in Coatings / Metals Harmful?
03/30/2009 8:37 PM
Persistent, bioaccumulative, toxic.
http://www.epa.state.oh.us/ocapp/p2/mercury_pbt/fact90.pdf
Theres facts aplenty in between the lines here:
http://www.ewg.org/node/21952
Basically, the rules are saying that the effects of CrVI are so bad, that they shouldn't be tolerated in the supply chain. Period.
But they are exempted for military applications, where it is understood that "S**T will die."
milo
You might be interested in: Wall Coatings, Architectural Coatings, Powder Coatings
