Am quite not so sure about SCADA system events like these in process companies, do these events really appear in their chronicle order or not? Take an example in SCADA system when the master computer polls (query) devices for response and two of them transmit at the same time on a LAN and both cease transmission and then signal that acollision has occured, each then tries again randomly. At the operator terminal you will actually look at them as if they are in chronicle order, is this really true yet other devices have transmited at a later time and their event appears first before the event that happend when the first two transmited at the same time and a collision was detected. I think if you rely on this for troubleshooting you may get wrong results, so is it really good to rely on these events for troubleshooting especially in situations where thousands of processes are being monitored and events appearing at the operator terminal.
Thanks.
