Previous in Forum: lighter liquid   Next in Forum: Shell & Tube Heat Exchanger - With Copper / SS Tubes
COAL PROPERTY
04/04/2009 1:42 AM
Dear all
Does any body know the angle of repose of coal with 50 mm maximum size? This parameter will be used to design the dome structure which can cover 40.000 Ton coal in storage.
Other properties of coal (typical) to be stored :
a. Coal Caloric Value : 5235 kCal/ kg
b. Total moisture : 35 %
c. Inherent moisture :18 %
d. ash content :1.6 %
e. Sulfur : 0.09 %
f. Volatile matters : 40.2 %
g. HGI : 46 %
h. Size ( 0 - 50 mm) : 96 %
Thank you all
Wien
Good Answers: 18
Re: COAL PROPERTY
04/04/2009 11:02 PM
As it is an easily measured property, I would suggest making a few quick tests on an actual sample rather than trying to estimate it. Also, at those high moisture content levels you may find that compaction of the finest sizes in the coal will tend to clump making any estimate inaccurate.
Re: COAL PROPERTY
04/05/2009 2:26 AM
what is the question?
Re: COAL PROPERTY
04/06/2009 1:49 AM
30-40 degrees.
It is easily measurable,so why not do that as suggested in post 1
sisira
Engineering Fields - Civil Engineering - Member Engineering Fields - Construction Engineering - Member Engineering Fields - Mining Engineering - Member United States - Member - Member Popular Science - Weaponology - Member Hobbies - Target Shooting - Member Hobbies - Car Customizing - Member
Re: COAL PROPERTY
04/06/2009 11:06 AM
Remember to ventilate the coal, if you don't you may lose it. Are you planning to use a covered, wedge-shaped pile? Typical angle of repose for coal is between 35 and 60 degrees. It is very specific to the actual coal, with moisture content and fines being a big concern. It is best to stack the actual product once or twice in smaller piles to see whatthe angle works out to be, and then lessen it a bit for safety.
You cannot escape the responsibility of tomorrow by evading it today - Abraham Lincoln
agua_doc (1); Anonymous Poster (1); Old Coal Man (1); Sisira (1)
