dear sir
I hope that you help me with the following fault message when i did hard ware
diagonistec check for the S7 cpu using on line connection AS, there is a ( bus fault
indication lamp flashing )for along period in my factory also(SF) fault lamp illuminate for
along period and the HMI on the profibus network has power but no any data or
program on it
AFTER CHECK the message was
DP slave not accessible by means of the bus
and by the check i found the status of the DP slave was:
module configured but not avialable, preset / acutal mis match (inserted and configured module type are not the same)
but over all the main program for machine still functioning and the machine in service
hoping for your response
thanks and best regards
