Previous in Forum: MS Billets   Next in Forum: rolling process
isotropic
04/05/2009 2:09 AM
What is a isotropic surface? Is milled surface and turned surfaces comes under isotropic surafces?
Re: isotropic
04/05/2009 10:17 AM
Why don't you people ever do any research before you come here?????????????????????
Isotropy - Wikipedia, the free encyclopedia
Re: isotropic
04/06/2009 4:40 PM
I found yur carping about people not doing research before referring the question to the forum distateful, but your reference to Wikipaedia very informative. So you got one vote for GA and one vote OT from me.
Please dont scare off people with such "holier than thou comment" as above. I for one learn something about anisotropy (especially of machined surfaces) which I will find interesting and useful, and for which I would not have learnt if the original question were not asked. So you never know who will benefit from the simplest of questions!!!
Re: isotropic
04/07/2009 9:40 AM
Are you having a bad day or are you always so angry? You had a similar response to this thread.
http://cr4.globalspec.com/thread/35959/water-calculation?frmtrk=CR4digest
If you don't want to help then don't bother answering.
Regards
Mr. W.A Snow
Re: isotropic
04/05/2009 2:42 PM
This is a surface finish ...Do a Google search it answers any further questions you may have. Yes to the second part of your question.
Re: isotropic
04/05/2009 9:36 PM
Hi 55418UND
Thanks a lot.
bsp
Re: isotropic
04/06/2009 9:47 AM
If you have looked it up you've got the answer; if not, here is a rough definition. Most machined surfaces have a lay, the direction the cutting tool was traveling in. Easily spotted when sanding, milling or turning a part on a lathe. The surface you are looking to achieve has no discernable pattern or direction, similiar to a lapped surface. Very uniform overall. Many ways to achieve this including technologies I haven't yet used. Are you looking to increase lubricity between dynamic surfaces?
You reap what you sow.
Register to Reply 6 comments
55418UND (1); BillV (1); bsp1535 (1); HoleInTheSnow (1); Lleros Marharg (1); lyn (1)
