Previous in Forum: How to measure RF Resonance of objects   Next in Forum: How Do You Tune an Electric Piano?
YT11 Yard Tractor
04/05/2009 10:54 AM
I have an Ariens YT11 Yard Tractor that keeps tearing up the Pan Belt. Local repair shops haven't been able to solve problem. Anyone have experience with this particular tractor? It has an unusual setup with belt only contacting about 25% of the Drive Pulley.
Re: YT11 Yard Tractor
04/05/2009 11:43 AM
04/06/2009 10:41 AM
There should be a belt tentioner on the by the drive on the slack side of the belt.
04/06/2009 7:45 PM
Yes the belt tensioner is working, almost. I may have put the bolts in upside down when I rebuilt it. It appears that one of the blade bearing housing bolts stops the tensioner from making full travel once the belt seats into the groove. I will reverse the bolt assembly and try it again. Thanks for the memory jog.
04/06/2009 3:32 PM
TRY TECUMSH FOR TRANSMISSION PARTS
DLS
Register to Reply 4 comments
Anonymous Poster (2); doitinastang (1); lyn (1)
You might be interested in: Flat Belt Pulleys, V-belt Pulleys
