Previous in Forum: Instrumentation Couse in M.Tech or M.E   Next in Forum: WHAT IS KVA
Clutch Design
04/06/2009 11:25 PM
Specifically, I'd like to know how to calculate and choose suitable hydraulic pump to engage and disengage the clutch system?
I am to design a clutch system (including hydraulic linkage system) for school work. I have worked on the friction material and clutch size. Any additional formulas to got more numbers to design the clutch is very much appreciated.
Im not sure to post in automotive or M. Eng so I'm posing on both threads. Sorry. Just need information asap
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Clutch Design
04/07/2009 9:24 AM
Hello Guest,
I've moved your thread to the Education forum since this project is actually school work.
If you studying to be an engineer, please consider registering with CR4 and getting to know us better. Registration is free and easy-to-do. Just click the Register link in the upper-right hand corner of the red bar.
Moose
Good Answers: 196
Re: Clutch Design
04/07/2009 11:31 PM
Guest --
First I would like you to think about the requirement for that part of your system that engages and disengages the clutch. Here are some questions only you can answer without giving the rest of us a detailed drawing of your system:
1. Will this operation be done upon some signal from an automated component of the system or will it be done by a conscious action of a human operator? If a human operator what body movement will do the job? Will a human operator be expected to hold the system in position either in the engaged state, the disengaged state or both? (see 4. below)
2. How rapidly will the engagement and disengagement take place? Too fast could cause destructive shock loads, too slow and friction heating and wear of the clutch surface might be excessive. You'll need an understanding of energy and momentum transfer issues, if not at the analytical level at least at a practical level.
3. How often will the engage and disengage functions be required to cycle? Too often and wear and heating problems are possible.
4. How much force is required to hold the clutch in each position? How will this force have to vary for various operating conditions of the system? (different speeds, power levels, environmental conditions like shocks and vibrations)
5. What temperature range will the hydraulic actuator have to function in?
Now, go closely study a manual transmission clutch system in an automobile, preferably one with a mechanical rather than hydraulic clutch. All the basic requirements will be there in both a hydraulic system and a mechanical system; but they may be somewhat more obvious when you view the mechanical system. Best to search out a well illustrated pictorial representation. You will likely find 6 different kinds of springs in the system between the driver's foot and the engine flywheel engagement surface. Each has a function related to my questions 1 through 4 above.
When you find a link to a good diagram post it here so we can find it and use it in our discussion. I suspect the first question you will ask is something like "I can only find 3 or 4 of the springs. Where are the rest?"
Oh, BTW, please tell us what educational level are you working at?
Ed Weldon
