Previous in Forum: Free Gerber Viewers?   Next in Forum: Fillet Welding - Penetration Depth
Upsetting Machines and Screw Presses
04/07/2009 3:34 AM
To buy a (Head upsetting) Screw press How can we calculte the capacity of the press? for example to form a head of 100 dia in 50 mm rod of material En 19. kindly suggest me any website regarding Forging by uplifting screw press.or any formula is there?
Pathfinder Tags: Friction drive screw press
Re: Upsetting Machines and Screw Presses
04/08/2009 1:26 PM
Hi smicrofit, A forging press with appropriate load- stroke characteristics can be selected if the load-stroke requirements for the upsetting process in question are known. Often methods based on experience, empirical formulae & analysis are used for predicting forging loads. Please visit the web pages of " Enomoto Machine Co., Ltd. Japan "- www.enomt.co.jp/ New Files /htm-e / definition-e.htm & select " Evaluation of Capacity Procedure ". Hope you will find some of the best calculations. Good Luck. Rangasamy
Let noble thoughts come to us from every side.
04/08/2009 11:24 PM
Thankyou sir for ur valuable reply. As you said it requires experience , can you please suggest any experienced consultant in this ,as we are very new to this process.
04/09/2009 12:14 PM
Hi smicrofit, If it is going to be only one time help, then you can ask your screw press supplier like ENOMOTO, Japan Or SCHULER, Germany. For continued technical help, you can approach DEFORM. Their Web site is www.deform.com. These companies may have their local offices/ reps in your country also. Please contact them with full details like max. & min. size / weight of the entire range of parts, various material Spec. to be forged or upset, details of other equipment etc. so that an optimum solution is given. GOOD LUCK.. Rangasamy
04/10/2009 3:51 AM
dear sir
actually I have plan to buy Uplifting screw press from indian supplier like NHK hammers,to forge a hex bolt of M36 x 200 mm.But the supplier inturn asked me the capacity of the press? Can you suggest for this product what is the capacity of the press reqd & also Trimming press is it rqd or not.
sivakumar
04/12/2009 10:05 AM
Hi smicrofit, 200 ton capacity screw press is more than sufficient for these types of Hex. Bolts. Go for a 100 Ton Trimming Press-may be a " Mankoo " make. Choose an H frame type for better rigidity. Please visit their Web site : www.mankoopresses.com You may also ask NHK Hammers to counter- check your choice. Good luck. Rangasamy
04/13/2009 12:42 AM
thank you sir
i will check & come back.
Register to Reply 6 comments
