I am trying to find a reliable and accurate way of calculating the position and therefore plotting a symbol on a 'map' (square image) of which the co-ordinates of the oposite corners are known.
As I understand it this is quite straight-forward if my 'map' straddles the equator as my map is square and the Lat/Long lines are 'almost' square at the equator. However it becomes more complicated the closer to the poles one gets as lines of latitute converge.
Does anyone out there have suggestions (or formulea) for the adjustments required for Latitude.
I practice I do not need my maps to extend to the Arctic/Antarctic Circles. I am only interested in Latitudes between 65deg N & 56deg S.
Any suggestions/links/comments etc. will be greatfully received.
Ian.
