Previous in Forum: Rubber Cushions for Plastic and Glass Materials in LCD TVs   Next in Forum: Elastic moduli of Wolfram
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
ASTM A841 Grade C Class 2
04/08/2009 2:53 AM
As subject..
Is it common to replace ASTM A516 Grade 70 with ASTM A841 Gr C Cl 2 for propane storage?
Does anyone know about the max allowable stress of ASTM A841?
Thank you very much..
Please give respectful & positive answer than insulting! Respect each other ok..
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
Re: Does Anyone Know About ASTM A841 Grade C Class 2?
04/08/2009 6:05 AM
hi Premium,
about your first question (in the title), see the chart below. it you'd like a bigger image, clicking on the image will take you to the file itself:
for ASTM A516 Grade 70, its data sheet is here (http://masteel.co.uk/downloads/carbon.pdf - sorry, link no longer available).
both steels are for pressure vessels, but I guess the choice should be left to your client and not the fabricator. make sure material specs are clearly indicated in the client's requisition, and get their approval on any substitute material, in writing.
you might also want to consider other materials for propane storage.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
04/12/2009 9:24 PM
Hi langyaw..
Thanks for answering..
Anyways, is it common to use A841 material as propane storage tank?
One more question..
Do you have any info about its max allowable stress? I haven't found it listed in the stress tables..
Good Answers: 58
04/13/2009 6:33 AM
hi Premium,
ASTM A841 is a material for pressure vessels, no doubt about it. pressure vessels, on the other hand, are built according to strict codes, and per client's specifications. commonality of usage is something I don't know.
as to your 2nd Q, the stress data are available here. I believe the data is for sale.
Register to Reply 3 comments
