Previous in Forum: Hydraulic Cylinder Components   Next in Forum: Pipe Bending and Elongation
Bagasse Chain Conveyors and Fired Boilers
04/09/2009 3:23 AM
What are the important parameters which is to be consider in the alignment of a bagasse chain conveyor?
Also, what are the major faults that generally occured in atravelling grate of a bagasse fired boiler. ?
Re: Chain conveyor
04/09/2009 7:06 AM
group weight, tensile strength, and motor rating...........etc
Cheers,
Simon - www.piping-work.com
cheers,
Good Answers: 18
Re: Bagasse Chain Conveyors and Fired Boilers
04/19/2009 5:46 AM
Hi ,
Quite simply the control of the grate temperature is critical, you will find there is a tendency for slag to form as the ash melts readily then solidifies and then gums up the works. Grate temperature control possibly by means of flue gas recirculation is a possibility.But you will need to monitor the temperaure by some means of optical pyrometer. You will readily appreciate that you have changing conditions within the bed as fuel MC alters and loads change.Many biomass combustors are favouring a plate type moving floor with the fuel entry at the rear and ash discharge to the front with a large brick arch to reflect radiant heat back down on to the approach fuel mass. Is yours like this?
If it ain't broke,leave it well alone .........until it comes looking for you!
Register to Reply 2 comments
You might be interested in: Leaf Chain, Plastic and Metal Chain, Conveyor Chain
