Previous in Forum: Compressors and Modbus Communcations   Next in Forum: SCSI vs. EDI Hard Drives
Optical Multiplexer / Demultiplexer
04/09/2009 7:37 AM
Hello,
I need either seperates, or a 4-channel device to convert/multiplex digital signals to
optical to transit a fiber optic cable, and then to demux them and reclaim
the digital format on the other end. The catch is, that this unit(s) must be
small, compact and light weight. Any ideas?
thanks
Pathfinder Tags: optical demux optical mux
Good Answers: 50
Re: Optical Multiplexer / Demultiplexer
04/09/2009 11:23 PM
You could try DWDM. These devices are small, compact, and VERY expensive!
04/10/2009 10:02 AM
Not a terribly difficult or even interesting problem, has been done many times before. You need a stable clock source (Crystal controlled thank you), a 2 bit counter, or larger just ignore the higher order bits, a 4 line data selector, and the appropriate IC to interface your fiber. (depends on which fiber connector you plan to use)...
Good Answers: 12
04/14/2009 2:12 AM
Hi. Try www.osd.com.au. They have a number of different types of modems you are refering to...analogue, digital, IP. I have bought from them to do exactly what you request. I think they have anything from 1 channel to 16 channel types with/without data (ie to control PTZ of camera), audio, Ethernet.
The info you will need to provide though before contacting them (or any other manufacturer) is the type of fiber you are using or planning to use - multimode (cheaper but less distance) or singlemode (dearer but further distance is achievable).
Your benefit (if you are from the USA - they are from Australia) is the exchange rate - you will get about 30% savings without even starting to haggle!
Register to Reply 3 comments
Anonymous Poster (1); daffy (1); vermin (1)
