Previous in Forum: Process Flow Assumptions   Next in Forum: Automobile Automatic Gear
Cable Drum Engineering
11/16/2006 8:42 PM
Does anyone know of a standard technique used for designing cable drums. i.e for the length and weight of cable to be held and then fedfrom the drum.
Also interested in any information regarding the design and manufacture of very large cable drums.
Safety - ESD - RF Manufacturing ESD Installer
Re: Cable Drum Engineering
11/20/2006 6:51 AM
I'm not sure where you can find that info, but speaking as an ex-tower erector definately do your homework. I've seen drums collapse and tear right out of the front of hoists. The bad thing is its usually not the operator that gets hurt, its the person hooking up the load.
“The problems we face cannot be solved with the same level of thinking we had when they were created” Albert Einstein
11/20/2006 8:40 AM
Thanks jowens.
Good advice and at the forefront of my questions.
I actually found a really good Drum capacity calculator online (Ingersoll Rand) which is a great start. In fact, Now that we know the size, and we were pretty close with the initial calcs, it is now down to the strength, motorisation and breaking systems. Our Company structural engineers will be handling that part now. I am now under the impression that they will know what to do there. A lot at stake.
With regards to people in front of the drum, it is for the back of a ship and used to lay subsea cabling, so the cable just runs off the back of the vessel. No need for human intervention except at each end.
Thanks again
11/20/2006 8:41 AM
Check with overhead crane manufacturer. They regularly use these for overhead gantry style cranes.
11/20/2006 11:46 AM
Hi,
My company sells these cables and drums please email me at kellen@scorpionoceanics.co.uk and i will send you the cable reel calculator.
Best regards,
Kynan
Register to Reply 4 comments
Anonymous Poster (1); Johnoz (1); jowens (1); mjhub (1)
You might be interested in: Drum Heaters, Drum Pulleys, Cable Laying Services
