Previous in Forum: 1991 Isuzu Rodeo Won't Start   Next in Forum: 1997 Ford F-250 - Frame Width
14 comments
Subwoofer Power
04/10/2009 7:46 AM
i have connected Boss800 amplifed powered suboower(built-in-amplifer)
see the details
See the details of subwoofer& picture
Product Features:
MOSFET power supply amplifier
12-inch subwoofer
Phase switch (normal/reverse)
Thermal/short/over load protection circuits
Power & distress indicators
Variable low pass (50-150Hz) crossover
Soft delay remote turn-on
Adjustable input sensitivity
Remote level control
+12dB variable Bass Boost (@ 45Hz)
RCA low level input
High level input
Auto cooling
Signal-to-noise ratio: greater than 91dB
Max power: 1000 watts
Unfortunately i cannot get the deep bass might the require power is not getting, Do you think 12 volts battery of my car (Ford Explorer 2006 model) can providing the enough power to subwoofer please let me know if not then what modification i need to do.
Re: subwoofer power
04/10/2009 8:15 AM
You may need to add a second battery to power the amp.
Or, you could install some supercaps to take the "hit".
Try this link...
http://www.caraudiohelp.com/car_audio_capacitor_installation/car_audio_capacitor_installation.htm
HTH..
Re: subwoofer power
04/10/2009 10:37 AM
in need one Capacitor or two & please let me what type of Capacitor i need to purchase suggest me . sure it will solve my problem.
Thankz
Re: subwoofer power
04/10/2009 1:11 PM
I don't really see how any capacitor can provide more drive than a car battery...after all a car battery can provide surges over 100 amps when cranking the engine.
I'd say get it on a bench with a battery/power supply and test it out properly, there is probably a simple wiring problem, blown fuse/trip or 'finger trouble' as we call it in electronics design.
BTW. I am quite happy to be wrong on this, as trying to drive frequencies which can't sensibly be sustained in a car isn't my bag
Re: subwoofer power
04/10/2009 2:21 PM
The idea is that the capacitor will store enough power to "boost" the amperage during the very short duration of the bass note.
I have never used them, hence the link provided to give more info.
Cats have never liked loud noises anyway. (unless they were deaf...)
Location: Currently on break at home in Houston, Texas USA
Re: subwoofer power
04/11/2009 5:20 PM
A cap is not going to increase the punch from this sub. A cap will only tighten up the bass when the amp is suffering from a sagging power supply.
Re: subwoofer power
04/11/2009 5:34 PM
A second battery is not going to help this sub. My guess is it is rated at about 300W Rms. So, 25 amps is not going to pull down a car battery. And, don't waste your money on caps unless you need them.
Re: Subwoofer Power
04/10/2009 7:02 PM
I agree with the cat!
Nothing infuriates me more than some jerk/idiot/looser who pulls up beside me with his bass drowning out my radio.
It's an incredible invasion of my space.
Use larger wiring, as short as possible.
Re: Subwoofer Power
04/11/2009 5:17 PM
I see two problems with this device. 1. There appears to be inefficient amount of free-air volume in this size (SMALL) enclosure for a 12" sub to develop a punch from the lows. Because the the free-air volume is so low, the enclosure is more than likely tuned to to a relatively high frequency, i.e., 50hz or above. 2. An un-ported enclosure will develop a tight bass but the low-end punch suffers because the cone is not allowed to deflect as much as an enclosure with a tuned port. My advice for you is to return /sell it and purchase a ported, amplified enclosure. Bazooka makes a 12" amplified device that is considered a "Bass Cannon". I was quite satisfied with an 8" amplified device and the speaker lasted 10 years before it needed replacement. hope this helps
Re: Subwoofer Power
04/11/2009 7:33 PM
Sorry - Bazooka makes an amplified sub only as large as 10" but trust me, this should be more than adequate. If you are inclined and you have your heart set on a 12" sub, checkout Crutchfield.com. I have an 8" Polk dB Series in a Ground Shaker, ported enclosure (groundshaker.com) powered by an Orion sub amp (crutchfield.com) and it didn't set me back any more than the 250 clams that you probably spent on that "Boss". I had to decrease the size of the tuned port because it was rattling my teeth as it was. Good luck in your endeavor.
Re: Subwoofer Power
04/13/2009 10:56 AM
there is no way you need a secondary battery and power caps aren't gonna help your problem anything noticeable. it looks like when they jammed everything into a simple plug-n-play unit they seriously compromised on the quality of the box for the sub. I would say sell the unit and buy a sub that is separate from the amp so you can use a proper enclosure that isn't choking the sub.
South Africa - Member - Member Shonver
Re: Subwoofer Power
04/14/2009 5:56 AM
What you need is to understand what low frequency response (curve) will give you the required performance. Then measure your current setup's LF response with all equalisation settings flat (this would be an acoustic measurement). You can then add whatever equalisation is needed to give you the required response (using either built-in equalisation or an add-on component such as a parametric equaliser). Hopefully the current setup will have the required headroom (i.e., amplifier power and excursion) to accommodate the necessary equalisation boost/cut. The alternative is to swap out your current LF system for one that has a tuning characteristic that compliments your motor vehicle acoustics to give you the desired response.
DON'T PANIC
Re: Subwoofer Power
06/21/2009 3:31 PM
Dear All,
First of all thanks for providing the comments, As suggested some of u i bought the car subwoofer pioneer 12" 1200watts MAX RMS 400 installed in slead box as recomended by pioneer & powered to pioneer GM- amps 5400-t 760Watts Max with 2 channel, I bridged the 2 channel it became 360 RMS . Unfortunately still the same it is not hitting as it hard. do i need to install the cap if yes then what type of caps i need to connect please advise.
Re: Subwoofer Power
06/21/2009 4:11 PM
you need a ported enclosure to get the kick that you want.
Re: Subwoofer Power
06/21/2009 7:31 PM
This amp - is it a sub-amp?
Register to Reply 14 comments
azzu12399 (2); Calnet42 (2); lyn (1); Shonver (1); skeptical guy (1); tropicalspeed (6); user-deleted-1105 (1)
