Previous in Forum: Synchronizing Variable AC Drives with Different Ratings   Next in Forum: Samkot
Grid Tie Inverters
04/10/2009 12:09 PM
Con i used a coleman inverter 1200w 120v 60hz for a grid tie inverter ? help me
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
Re: Grid Tie Inverters
04/11/2009 7:16 PM
Without knowing the specs for the Coleman inverter you have... NO
I assume Coleman are distributors for camping and household general use inverters and do not provide the extra "bitz" essential to tie to grid. Synchronizing your home brew inverter to the power grid requires more than just hooking up your general use inverter...much much more and typically out of the realm of the average bloke on the block to build/modify.
CraziestOzzy
You might be interested in: Tie Down Straps, Hydraulic Cylinders, Air Cylinders
