Hi, Every one. Here I have one problem for your expertise help.
We just started a dryer a few of months agao and we found that the steam-tube rotary dryer can not handle enough solids as it was designed.
It seems that the dryer can provide enough heat capacity as the solids can reach the specified temperature with lower steam pressure. While the solids was accumulated on the dryer feed end if the dryer was fed to only 95% of the rated capacity even the feed cake moisture is lower than the original design.
So we are trying to increase the dryer solids handling capacity through modification, while I am not quite sure what is the difference between increasing dryer RPM or increasing dryer slope in terms of solid handling capacity. Can some one help me to understand that and help me to figure out what's the way to go (Increase the dryer speed or increase the dryer slope)
Thank you very much for your attention and Best Regards
