Previous in Forum: Coolant Temperature Sensor and Coolant Temperature Switch   Next in Forum: Sintered Bush bearing design
Car bumpers
04/18/2009 12:31 AM
Today most of car bumpers are made of pp+epdm. what is the basic reason behind using this blend? why not only PP or any other material? Is there any other material being used elsewhere ( in plastics )? Plz provide some data if available.
Thanks in Advance,
Heman2727
Re: Car bumpers
04/18/2009 5:13 AM
I would guess the EPDM helps it recover from minor impacts while the PP adds some rigidity. I would assume the blend is chosen to provide the properties required in a bumper. So think of the properties you would require in the ideal bumper and work from there.
Cost, compatiblity of materials, weight and other factors will come into it too.
Good Answers: 62
Re: Car bumpers
04/18/2009 9:43 AM
along with Del, I suspect the formulation was derived from early plastic bumper protests of sun fading and embrittlement and impact susceptibility.
Popular Science - Weaponology - Cardio-7
Re: Car bumpers
04/20/2009 1:05 PM
Polyurethane microcellular foam was the standard for many years, but the foam was more difficult to paint and the PU was much more expensive that the current PP + EPDM rubber mix. The current rubber forms can also be recycled, depending what the diene monomer is in the EPDM.
Re: Car bumpers
05/03/2009 5:18 PM
why not people make bumpers have same material, same shape, same size, same distance from floor?
Register to Reply 4 comments
agila (1); Cardio07 (1); edignan (1); user-deleted-1105 (1)
