Previous in Forum: project on asimo   Next in Forum: Boiler feed pump
Boiler feed pump
04/18/2009 2:24 AM
Can any one tell me about balancing&counterbalancing disc in boiler feed pump?where they are located?
Re: Boiler feed pump
04/18/2009 2:40 AM
Balancing correction was made by removing material on the Impeller surface (on the cover or Back Side) and the Balancing should be proccessed by Individual Imppeller first than to Assembly Balancing. If the design of Impeller is was there a groove rounding on the Cover side (Closse to the Eye ring) is mean the balancing correction is made by moving or adjust the position of the counter weight inside the groove.
You might be interested in: Boiler Services, Boiler Controllers
