Previous in Forum: Boiler feed pump   Next in Forum: Material stress values
Steam turbine
04/18/2009 2:37 AM
What are the methods which can be used to reduce the axial and radial clearance in turbine?
Indonesia - Member - Practice Engineering Fields - Mechanical Engineering - Practice
Re: Steam turbine
04/18/2009 2:56 AM
is complex, but why you want to reduce ? is to big clearances ? May the idea is was : Your Steam Turbine should be repair/overhaul to recondition.
" PRACTICE MAKES PERFECT" by : MK. Gandhi
Good Answers: 58
Re: Steam turbine
04/18/2009 6:11 AM
subhranshshekhar Pray tell. what course are you doing? You have asked something like 15 questions, all in the same manner and all related to the same subject matter. If there is something that you specifically do not understand there are many people willing to help, however it looks to me that you are asking us to do your research/homework for you.
Re: Steam turbine
04/19/2009 12:57 AM
It is too general to answer easily.You should know some prequisite: the types of bearings, the concept of alignment and relative /absolute expansion and many other things about rotating machines among them specially steam turbines.Did you pass prereqisites?
Re: Steam turbine
04/20/2009 2:46 AM
You could use carbon or something else to be abrade, then you will have only the smallest clearance.
Regards
Good Answers: 123
Re: Steam turbine
04/21/2009 9:39 AM
Wooden wedges.
Wrap with duct tape.
Spray foam.
Bob
Re: Steam turbine
04/21/2009 1:30 PM
Machine mating parts very carefully.
Pineapple
Register to Reply 6 comments
agung jelantik (1); Anonymous Poster (1); bob c (1); moheshams (1); Pineapple (1); The Prof (1)
