Previous in Forum: Waterjet Technology   Next in Forum: Problem in Nitriding
11 comments
Machining of Quartz Material
04/22/2009 12:49 AM
I am facing problem to turn parts of quartz material on my CNC Lathe. The inserts are chipping / wearing out very fast. Can somebody suggest me whats the best tooling, coolant etc., i should select for turning. Also can somebody share your experiences on turning quartz material to increase productivity & quality.
Good Answers: 183
Re: Machining of Quartz material.
04/22/2009 4:51 AM
I would prefer grinding in stead of turning. The local "cutting speed" is better for a good result.
04/22/2009 5:24 AM
But the Outer & Inner dia has lot of profiles,steps,features etc.,
04/22/2009 6:51 AM
Need inserts which are harder than your quartz, but still tolerant of the shocks etc of machining.
I believe there is a polycrystalline alumina tip made which should do the job.
It won't be cheap.
What you can afford to use depends on the quantity you need to machine.
Good Answers: 146
Re: Machining of Quartz Material
04/22/2009 10:33 PM
I don't know about turning, but after seeing how a diamond bit cuts into quartz, I would recommend diamond cutters/blade or whatever, above any other tool material for quartz.
incus opella
Good Answers: 94
04/23/2009 6:53 AM
Is this natural quartz or manufactured fused silica? As mentioned in other posts, these materials are normally ground rather than turned, there is no difficulty in creating steps, holes etc by grinding. The natural quartz may contain weaknesses which can lead to splitting if it is not machined in the correct orientation.
04/23/2009 6:59 AM
Maybe a live tool? Wet grinding with small diamond wheels?
I have found that honor lies in doing the right thing even if no one is watching. Dignity lies in letting others take the responsibility and character lies in being able to smile as you walk away.
04/23/2009 7:47 AM
A diamond cutting tool using very small feed rates will work. It's a slow process, but if done correctly it can result in a very good finish. If I recall correctly, you also need a very rigid, almost vibration free setup to get good results.
04/23/2009 7:49 AM
I neglected to log in. The previous response is mine.
Good Answers: 22
04/23/2009 9:42 AM
If you look up Gran-Quartz on Google, you will find a wide array of machining bits for use on granite and quartzite. If you are using a natural material, I would guess it is likely quartzite, which is metamorphic and nearly as hard as diamond.
04/23/2009 11:29 AM
Varadharaju:
I have been cutting quartz for many years. I would recommend that you use diamond cutting tools with a flood of coolant that is the same temperature as the quartz.
At least for the initial cutting cycles. Also use higher cutting speed of the tool and be careful of the depth of cut.
Remember that diamond has a very specific grain structure. Think of it like a piece of wood. If you do not have the speed and feed correct for the cutting tool it too will chip and fail.
Good Luck
Lawrence Beshore
Location: united states, california san francisco bay area native
04/23/2009 3:37 PM
yes the key to turning the material is the orientation of the " grain "...speed is secondary.. chipping is because the work is leading and not trailing the cutting tool...keep the tool sharpened... and cooler than the material.. and patience.. standard 3mm bite is toooooo much for quartz or any subs to quartz...
give the hardest job to the laziest person & they'll find the easiest way to do it
Register to Reply 11 comments
ahuha (1); Anonymous Poster (1); artsmith (1); ddphillips (1); Doogleass (1); Lab Rat (1); Lawrence Beshore (1); nick name (1); Nigh (1); sceptic (1); Varadharaju (1)
