From the cable data's you will require 4Cx16sq-mm size cable for your power and earthing or you can use 3Cx16sq-mm for your power and for earthing cable you can selects 10sq-mm or 16sq-mm
just asking...ur panel incoming is 40A but why your bus bar rating is 25KA...seem too high...or am i wrong...if you follow incoming cable, you can size ur earting either 16mm2 or a little bit lower..but if you size according to the fault level 25kA your earthing probably around 70mm2...refer to ieee std 80-2000 for additional info.
