Previous in Forum: Knee point Voltage of Class X CTs   Next in Forum: 3-Phase to Single Phase Distribution
ID Fans and Currents
04/27/2009 3:22 PM
why current of ID fan so vary in running condition ( varry between 50 to 200A, for 132 KW, 960 rpm & FL current of motor is 227A)
Re: ID Fans and Currents
04/27/2009 4:08 PM
ID fan = Induced Draft fan?
04/27/2009 5:31 PM
To guest: Yes ID fan=Induced Draft fan (at least everywhere I have worked).
To OP: Since you don't mention a VFD, I have to guess (I hate guessing) that you have some sort of damper vanes. Two things to check: 1. Is there any slop in the mechanical linkage. 2. Check the PID loop that controls the dampers, if it is tuned too fast it can cause oscillation, which would show up as variable amp draw on the motor.
If neither of those is the problem, then start looking at the feed/process that the ID fan is used for (Boiler, Furnace...). It could be under/over feeding sporadically.
Good luck!
Good Answers: 137
04/28/2009 7:04 AM
Steady on Kilowatt0
He didn't say it was a problem, maybe he's just asking out of curiosity.
This sort of input power variation over fan duty range is not unusual. Power usually increases with reducing fan pressure and increasing flow).
Cheers...........Codey
04/27/2009 11:10 PM
Current varying over what period of time? motor oscillating or over a number of hours?
Regards JD.
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
04/27/2009 11:27 PM
What type of fan is it?
If more than one, how many fans interconnected? (I have witnessed a fan failure on a 500MW boiler where one fan was in a stall condition for several months in 3-fan-in-parallel configuration - and it wasn't a power saving exercise. It was a bit like the proverbial turbine blade through the roof event)
Centrifugal with or without inlet guide vane control?
Axial Flow with or without inlet guide vane control?
Is fan operating duty variable using motor speed/ inlet guide vane/ outlet damper?
04/28/2009 1:04 AM
HI Friend,
tell me you put What type moter that is saquiral cage or silpring motor becase slip ring moter always having small fluxvation due to not praperly geting the star point at rotor side
check your damper possition may be damper fluxuate to maintane the furnace draft
when we put the VFD for the pannel for the motor we may control the assilation by adjusting rampup and ramdawn time
04/28/2009 5:45 AM
The fan load keeps varying depending upon the air requirements.Second Inertia of ID fan is high.heck the starting time at start on DOL.dampers are used to vary the speed of fan.Now a days VFD is used which results in energy saving when motor has to run at different speeds
Register to Reply 7 comments
Anonymous Poster (1); AussieBob (1); B.JEYACHANDRAN (1); Codemaster (1); jdretired (1); Kilowatt0 (1); nesubra (1)
