Previous in Forum: 98 cavlier   Next in Forum: Free Vibration in Buses?
14 comments
Free Vibration in Trucks
05/03/2009 12:05 PM
can anyone tell me..where free vibration occurs in trucks i mean in which components?whether damped free vibration or undamped free vibration.
Hashim Khan,Automotive engineering Student
Re: Free vibration in trucks??
05/03/2009 1:38 PM
Everywhere!
Can you name a part that doesn't vibrate?
Maybe the seat squabs don't vibrate, and the seatbelts, but just about evrything else vibrates to some degree.
If you really insist on an answer, then I'd start with the exhaust system, and the suspension, which obviously has components inserted specifically to dampout vibration.
05/03/2009 2:45 PM
thanks..for the description,i knew that.but
i am looking for the components that will exhibit free vibration?correct me if i am using the wrong term.A professor has asked me about it,i am also confused about the term free vibration..i know this type of vibration doesn't exist in real life but still free vibration with some damping in trucks is the question..
05/03/2009 8:48 PM
Not my area, but could your Prof be referring to sprung and un-sprung masses. The masses involved with the axles etc are unsprung, where the chassis and body etc are sprung. Engine is supported on "spring" system (mounting blocks), the passenger is "sprung " etc??????
Good Answers: 97
05/04/2009 12:27 AM
Free vibration occurs in the rotating parts and is communicated throughout the vehicle.
Good Answers: 196
05/04/2009 3:11 AM
Everything in the universe that has mass and elasticity "rings". This includes all the solid parts of a truck as well as the various assemblies. Put some mechanical energy into them and they will usually ring at their natural frequencies as long as they are not constrained from moving. The less dampening there is the longer it will take the ringing to die down. Just like a bell. That is all free vibration. There is also forced vibration from machinery motions that can excite motion and even destructive resonances at the same time as the free vibrations often masking them. That's not what we're addressing here at this point.
Free vibration is going on all the time; but in a well designed truck it is either constrained or not a noticeable problem.
An example of free vibration in a vehicle is the motion of the body on the suspension springs due to a rough roadway when shock absorbers are inadequate for the task. Another rare example is when an engine over revs to the point that the valves "float" away from constraint by the valve train and valve seats. And the most common example is the noise environment in the vehicle that is the result of structural vibrations some of which are the consequence of free vibrating parts of the vehicle that are responding to general vibration and minor shock environment present.
Another important thing to be aware of, and I will hasten to admit that I cannot give a good simple explanation of it, is the example of a simple bell. When it rings it produces sound that comes from vibrations at its resonant or fundamental frequency. If I were to take a small speaker attached to a signal generator that could be adjusted to produce exactly the same frequency as the bell, put it near the bell and turn the volume up the bell would start to ring on it's own. This is a "forced vibration". Raise or lower the frequency of the signal generator and the ringing quickly decreases.
Now, if I take a small hammer and tap the bell with a sharp stroke the bell will also ring and die down due to the fact that its metal structure has some dampening in it. Strike it again and it will ring. What's going on here?
Well the short answer is that any impulse of energy that is other than a perfect sinusoid contains additional exciting frequencies. A perfectly sharp impulse contains all possible frequencies. So the one to excite the free vibration will likely be there.
The long answer, by the way has to do with the math of fourier analysis. Hopefully someone better equipped than myself will give us all a good explanation.
Ed Weldon
Good Answers: 97
05/04/2009 3:36 AM
I was going to give a good simple explanation of but thought the professors assignment had designated the student to do the research.
Free vibration occurs when a motion is induced and an oscillation develops about an equilibrium.
05/04/2009 6:45 AM
well i have searched on it already and found free vibration specifically in the cab of trucks..mostly due to the imbalance wheels not because of road condition..thats wot i have found...thanks ed weldon for the description its very helpful to me..
vote of thanks to all the friends also..
Good Answers: 196
05/04/2009 11:45 PM
At 100 km/hour a truck with an unbalanced 1m dia wheel will produce a roughly sinusoidal vibration impulse at around 9 hz. This is well within the range of human perception although what you actually hear coming out of the truck cab are higher frequency components. You can also feel the vibrations and in some cases see them. Large sheet metal structures can easily have vibration modes in the 9 to 10 hz range, especially if there is any looseness in the connections (or maybe crude engineering that didn't identify and correct all the rattle makers at the design stage). Nevertheless what you are observing are primarily forced vibrations.
Free vibrations are really something we have defined to ease the teaching of the subject. So we say that it is a free vibration if we have a system with elasticity and mass and introduce potential energy into it without any significant motion of the system and then allow this energy to be released to set the system in motion. The system alternatively converts the energy from potential to kinetic and back again at some fundamental or "natural frequency". In the classroom we often start with a weight hanging from a soft spring attached to something solid at the top. We gently pull it straight down and carefully release it. It vibrates up and down at its fundamental frequency calculated as the square root of spring constant divided by mass.
We quickly go off to argue about the effect of the mass of the spring, dampening that eventually makes the whole thing stop moving, etc. What we miss at the beginning is the consideration that this vibration caused by a release of stored energy is a relatively rare phenomenon. Also rare is the simple system with only one mode of vibration, a point mass and a mass spring that has no mass but nevertheless moves part of the time and therefore has some kinetic energy during that time.
Most mechanical vibrations in our physical world have a component of energy that is from a forcing source and a component that is a free vibration. The question of whether a given vibration case is forced or free is really up to how one chooses to define the boundary between the two in numerical or mathematical terms as it may apply to the given case.
I suppose you could call it a free vibration if it is still "buzzing" after the truck stops. Of course if you have a sophisticated structural analyzer and accelerometer that can store a time domain vibration spectrum or an FFT vibration mode signature from an impact test and later calculate the difference between it and a vibration signature taken when the truck is operating you could set some boundary definition that would allow you to decide whether the observed vibration was free or forced.
Ed Weldon
Good Answers: 97
05/05/2009 12:22 AM
Free vibration may be observed in the hollow drive shaft of trucks. In the instance a gear is engaged and the clutch brake not engaged the shaft may ring.
Good Answers: 123
Re: Free Vibration in Trucks
05/05/2009 10:20 AM
The closest thing I can recall is a store on US 1 that has buy 1 get 1 free on vibrators.
Bob
Good Answers: 97
05/05/2009 7:48 PM
A spin cycle?
Good Answers: 123
05/05/2009 9:07 PM
Do you know where I can buy training wheels for my spin cycle?
Bob
Good Answers: 97
05/06/2009 1:00 AM
Second stall at the wringer mart
05/06/2009 1:45 AM
Are you a student?
Stud?
Register to Reply 14 comments
Anonymous Poster (1); bob c (2); bwire (5); Ed Weldon (2); lyn (1); studcentury (2); user-deleted-1105 (1)
