Scientists at the Laboratoire Léon Brillouin near Paris in France have found that when solid oxygen is placed in pressures exceeding 80,000 atmospheres, it loses its magnetism. I just think its amazing they can apply 80,000 atm to solid oxygen.
At one point in the process there is an area between being magnetic and being a superconductor, there is a spot where solid oxygen is not magnetic. If you know where that boundary is you can more easily toggle between those two states.
"The future is here. It's just not widely distributed yet." -William Gibson
Ok, technically it's not magnetic its paramagnetic. I means that liquid oxygen can be manipulated by a magnetic field without having a field of its own. Here is a few theories about why this happens.
This seems to fall into the category of "because they can" - they wanted to find the actual point in what had previously been an understood range. I agree though, whatever pump system they are using to achieve 80,000 ATM would be awesome to see in action.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
