Previous in Forum: How to Dispose of Mercury   Next in Forum: igc garde
Gluing a UV Coated Surface
05/05/2009 11:06 PM
Need advice and recommendations from expert in gluing.
I am designing a household product which required to coat with UV painted on it.both joining area is in cyclinderical shape with 14mm in diameter, does this surface able to be glue to form a strong joint? type of glue?
regards,
surface
Re: can UV paint coated surface be glue?
05/06/2009 1:50 AM
What do you mean, "with UV painted on it"
please try to be more descriptive. clear.
you are putting a coating on something and you want to know if you can "glue" to the coating????????????????????????????
05/06/2009 2:03 AM
Hello Lynlynch,
sorry for the confusion, i mean after the plastics substrate coated with UV paint, does this coated surface can be gluing?
thanks,
Surface
05/06/2009 9:09 AM
You will need to identify the type of paint your UV paint is. From what basic materials is your paint produced. You can "glue" the items together, but the bond will only be as strong as the weakest interface. Substrate/paint/glue/paint/substrate.
Good Answers: 16
05/06/2009 12:45 PM
Epoxy with a UV stabilized hardener may be used to glue most anything except certain plastics. Powdered colors may be mixed in with the epoxy, like chalk line colors from a hardware store. If you wish to glue hardened epoxy surfaces to each other, you will have to clean with water with a few drops of detergent, and wetordry sandpaper or Scotchbrite. Rinse with clean water. To fill gaps use a thixotropic, like talcum powder, or microballons. Colloidal silica will thicken and reduce running. Again, clean an rinse between steps where the epoxy has hardened
Am I getting close to the information you are looking for?
Spend some time experimenting with the stuff, wear latex or vinyl gloves, plastic on your work bench. Have fun.
De gustibus non est dispudandum.
Re: Gluing a UV Coated Surface
05/07/2009 11:40 AM
I have had good luck with LSD adhesives (Low surface energy) 3M provides an adhesive tape (double sided) called PT 1100 Avery also has one but I had better luck with 3M.
I used this to bond an EPDM rubber seal to and ABS substrate and also a Painted surface (exterior automotive application). The EPDM rubber had to be treated with an adhesive promoter but was not necessary for the ABS and painted surface.
~Good Judgement comes from experience... and a lot of that comes from Bad Judgement! ~The Early bird may get the worm.. But the second mouse gets the cheese!
Good Answers: 37
05/07/2009 2:52 PM
From today's New Equipment Digest newsletter on Adhesives, Chemicals, Lubricants, and Sealants:
ASC Launches New Adhesive and Sealant Educational Website
The Adhesive and Sealant Council, Inc. (ASC) has a new web portal dedicated to engineers, designers, architects, and others who wish to understand the benefits and advantages adhesives and sealants bring to modern product design and assembly. The Adhesive and Sealant Council, Inc. (ASC) unveiled a new web portal dedicated to engineers, designers, architects, and others who wish to understand the benefits and advantages adhesives and sealants bring to modern product design and assembly.
Click HERE for more information.
" Ignorance and arrogance have more in common than their last four letters. "
Register to Reply 6 comments
lyn (2); Part time thinker (1); Ron (1); surface (1); Tippycanoe (1)
You might be interested in: UV Filters, UV Sensors, UV Light Systems
