Previous in Forum: Tan Delta Tests for Transformers and Transformer Bushings   Next in Forum: Three-Phase Voltage Connections and the U.S. Electrical Grid
Back Torque and Back Force in Linear Generators
05/06/2009 10:34 PM
Hello,
I am trying to understand the back torque (in circular generator) and back force (in linear generator). When you turn the dynamo, you apply some force. Different dynamos has different force requirements.
1) Do the back torque/force come from cogging force?
2) Is it induced by Field generated by current inside the magnetic wires?
3) How to calculate back torque/force when mechanically powered? On paper, they should create an equal opposing force to the mechanical force/torque applied. Am I missing something?
Thank you.
Good Answers: 73
Re: Back Torque and Back Force in Linear Generators
05/07/2009 9:20 AM
Electromagnetic energy is just another form of energy. Kinetic energy is pretty obvious because you can see stuff moving. Electricity is invisible but you will realize it is there as soon as you contact the appropriate conductors.
The answers to you questions can be found in Sir Issac Newtons laws of physics. In particular, for every action there is an equal and opposite reaction. So, when you move the coils of a generator through high energy magnetic flux lines, a voltage is induced. But a voltage with nowhere to go will not create any back force. For that, you must have current flow. Together voltage times current equals power. Once you have that, you can determine all of the other relationships like torque and so on.
Stability, balance, and capacity are advanced issues.
05/08/2009 2:41 AM
See Lenz's Law.
One of the first experiments I witnessed in Freshman physics (that's as far as I got) was one involving a hand crank generator and a variable load. When there was no load on the generator the crank was pretty easy to turn; but as soon as there was a load placed on the generator the amount of work required to turn the crank increased dramatically.
Making a long story short, it brought me to the understanding that with a generator the efficiency of the generator will require that slightly more mechanical energy be applied to rotate the armature than is applied through the load circuit.
In a perfect machine the Work = Power X Time (electrical output) = Torque X angular displacement (mechanical rotational energy). Because no machine is 100 percent efficient it will require more mechanical energy input than that which can be used (or lost) in the load circuit.
The "force" required to turn the generator is the braking force used in electrical dynamic braking or regenerative braking in automobiles and locomotives. It is well understood by all those smart people who understand that stuff.
Electrical Generators and electrical motors have relatively high efficiency when compared to, lets say, a reciprocating heat engine.
A few decades ago, the primary producer of energy in a mechanical system was called the "prime mover." In an automobile or locomotive that "prime mover" is a reciprocating heat engine. I believe back then a reciprocating heat engine with an efficiency of 20 percent would be considered quite good. That means that for each unit of mechanical energy produced, 5 units of the fuel combustion energy is used. It is for this reason that regenerative braking makes so much sense. For each unit of kinetic energy converted to stored energy during braking and then applied to accelerate the vehicle during the next cycle, 5 units of combustion energy is saved.
The Mechanics of linear and rotational systems are pretty straight forward and easily understood with only a rudimentary background required for extrapolating the relationships between work and displacement in everything from electrical generators to asteroid deflection.
Recapping; I believe that in a rotational system the mechanical input: Torque X Angular Displacement will ≈ eff X Power X time where eff is the efficiency of the generator.
Gavilan
03/01/2015 10:00 PM
I am testing linear barcode generator and meet some problems in this filed.
So for a practical definition, the torque constant Kt specifies how many Nm of torque you'll get from the motor at a certain current? Is a bigger Kt always better?
I am more confused about the backemf constant Kemf. This is the amount of back EMF produced by the motor running at a certain speed. Does the back EMF limit the voltage the motor can accept and hence it's speed?
Would an ideal motor have a very high Kt and very low Kemf?
What happens if the back emf voltage reaches the input voltage, does the motor stop running?
Register to Reply 3 comments
bobbell (1); Gavilan (1); NotUrOrdinaryJoe (1)
