Previous in Forum: Building Codes and Bathroom Heating   Next in Forum: Motorcyle Speedometers and Magnetic Fields
9 comments
Kenmore Elite Gas Dryer Paddle Loose
05/10/2009 2:46 PM
Inside the dryer one of the paddles or fin-type things is loose. Can I glue it?
Thanks! M.A.
Good Answers: 16
Re: Kenmore Elite Gas Dryer Paddle Loose
05/10/2009 2:57 PM
Pop rivet it in place with some High temp. epoxy.
De gustibus non est dispudandum.
05/10/2009 3:07 PM
Thank you. Trying to understand the process. I can wiggle the paddle but it is still partially attached on one end. Do I need to remove the paddle 1st and do I need to open up the drum? Not sure how to access.
Good Answers: 16
05/10/2009 3:51 PM
Are there flanges on outside of the paddle edge? If so, get a pop rivet kit with some appropriatly sized stainless rivets. Drill through the flange and drum (1/8" drill and rivets, short shank). Pop into place. Forget the epoxy if you can get enough rivets into it. Your retailer should be able to show you how to use this simple and versitile tool. Check your warranty first. You may be covered if you have'nt "made any alterations" to it yet.
Location: united states, california san francisco bay area native
05/10/2009 4:15 PM
might be that the hardware that is attaching the tine to the drum is loose ...if the back is accessible.. the back of the drum would , might be , highly visible..maybe each tine has 2 screws securing it in place and you've got only one screw loose..?
opps..lol.. can you hear the other screw " bouncing " around when dryer in operation?
in all seriousness, hope this helps...
give the hardest job to the laziest person & they'll find the easiest way to do it
05/10/2009 5:14 PM
Thank you both very much - looking into the warranty. I am flattered you think I could do all this other stuff!
M.A.
Good Answers: 97
05/10/2009 7:13 PM
A self drilling/tapping sheet metal screw is what I used.
05/10/2009 11:34 PM
M.A. get a putty knife and push in at the two front corners this will allow you to lift the top of the dryer then rotate the drum so you can access the screws holding the paddles to the drum.
05/11/2009 1:40 PM
Thank you. Do I have to take off the front too?
Good Answers: 97
05/12/2009 1:38 PM
It appears the front should come off and it will but the best access is from the rear
ahuha (1); Anonymous Poster (3); bwire (2); roadapple (1); Tippycanoe (2)
You might be interested in: Process Dryers , Compressed Air Dryers, Plywood
