Previous in Forum: Coil Usage calculation in SAW   Next in Forum: Chemical Composition of St 55 Steel
8 comments
Hydraulic Cylinder
05/12/2009 6:07 AM
In order to design a hydraulic cylinder to move 100kg against gravity what should be the factors considered.Hydraulic oil to be used is HLP 46.
Re: Hydraulic Cylinder
05/12/2009 6:19 AM
Carry out a Force Balance: Newton's laws, that sort of thing.
Good Answers: 266
05/12/2009 7:22 AM
Does it need to push or pull.
Good Answers: 143
05/12/2009 7:26 AM
F = (1+δ)PA, where F is the force in N, P is the pressure in N/m2, and A is the area in m2. δ is a margin that allows for acceleration of the load, loss to seal friction, and a "fudge factor".
But, why design one? They sell them. Contact your local sales rep.
Good Answers: 143
05/12/2009 9:06 AM
And, I didn't point out δ is negative.
Good Answers: 15
05/12/2009 7:27 AM
A sketch of your application would be appreciated.
How much Pressure is your hydraulic system producing?
What is the range of air temperature? Then you can figure out the viscosity range of your oil.
How fast do you want to move the mass?
How consistent does the speed need to be?
How long are your hydraulic lines? Then you can figure out your line losses.
Is your hydraulic power pack above or below the application?
Have you actually gone to a hydraulic component supplier catalog and looked through their engineering aids? Most of the hydraulic catalogs I've gone through have several pages of help.
downhill slide to 112 (damn memor.)
05/12/2009 9:01 AM
Since you obviously know nothing about cylinders and I doubt very much that you could design one anyway, just go to the internet, select a couple of likely victims suppliers and contact them with your question.
It's comforting to know that you have the oil tied down.
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
05/13/2009 8:56 AM
These links go from the basics to the formulae required:
http://en.wikipedia.org/wiki/Hydraulic_cylinder
http://science.howstuffworks.com/hydraulic1.htm
http://www.indianafluidpower.com/Formulas.asp#HydraulicCylinderCalculations
http://www.hydraproducts.co.uk/Hydraulic-Calculator.htm
http://www.precisionfluidpower.com/fluid_power_formulas.htm#cylinder
After that you need a good seal catalog:
http://www.gulfcoastseal.com/downloads/eps5370.pdf
Be careful of your material choices since many of the clearances may have issue at temp.
The hydraulic cylinder is only a small part of a fluid power system required to complete this task.
BTY- custom built cylinders are cost prohibitive.
-why bother doing it wrong when it will be anyway.......
05/13/2009 8:59 AM
Like my other colleagues have stated, does the application require pushing or pulling the object? Where are you going to place this cylinder? I think the space you supply for it is important. Are you going to attach a nut or something so that it may work?
Anything can be made... With time, money and brains.
Register to Reply 8 comments
95324 (1); Anonymous Poster (1); ddk (1); gdevine (1); lyn (1); ozzb (1); TVP45 (2)
