Hello. Do you know the calculation of the voltage raise when a phase on the secondary is short circuited to ground ? The sistem is a 23 KV / 440 V trhee phase DELTA DELTA circuit (This means thereis NOT a ground in the secondary). I need to know how much the voltage is raised in the another 2 legs of the secondary transformer. I have the clue that the voltage rais will be: 1.73 * V (where is the rms voltage and 1.73 is product of square root of 3).
Thank you in advance.
