Previous in Forum: Heli-Coil Hand Installation Tools   Next in Forum: Heat Treatable Swivel Materials ?
Synchro-to-Digital Converter
05/15/2009 2:19 AM
I am looking for a Synchro-to-Digital Converter on a stand-alone board or unit for reading angle position information from a Clifton Synchro-Transmitter (Y-shaped stator, 3-wire, 26VAC/400Hz reference voltage to the rotor). 12-14-Bit resolution needed.
Re: Synchro-to-Digital Converter
05/15/2009 3:02 AM
Google synchro resolver digital and start trawling through the dozens of possibilities.
Good Answers: 25
05/16/2009 2:15 AM
I have used the older versions of North Atlantic APIs, mechanical and electronic.
Resolvers too.
05/15/2009 9:27 AM
DDC and Aeroflex make S/D's
05/16/2009 12:38 PM
You can track back the phase angle measurement to a simple time ratio measurement. The time (t) between the -/+ transition of the reference voltage and the -/+ transition of the rotor output voltage will be linearly proportional with the phase angle. You only have to know the exact period (T). If you have a simple PIC you can write a very simple program in order to evaluate the T and t and convert the ratio to degrees or radians.
Aged man is not old man...
05/17/2009 6:55 AM
You only need a PIC with two analogue inputs and a counter. Either analogue input is connected to the reference voltage, the other one is to the rotor output. The program of the PIC is the following one:
1. Find the first -/+ transition of the reference voltage
2. Start the counter
3. Find the -/+ transition of the rotor voltage
4. Store the counter value (td)
5. Find the next -/+ transition of the reference voltage
6. Store the counter value (Tp)
7. Divide td with Tp and multiple the result with 360: That will be α, the phase angle in degrees.
8. Display α
9. go to step 1.
The accuracy depends on the counter frequency and the accuracy of the analogue inputs.
06/23/2009 11:13 AM
this solution can't be used as angle detector.
synchro devices modulate refrence signal in AM mode,all S1,S2,S3 signal have same frequency with phase 0/180.
some thing like Average and magnitude detection with mathematical solve must be used as in MCS usage sysem.
Register to Reply 6 comments
Anonymous Poster (1); bhankiii (1); JohnDG (1); kudukdweller9 (1); Qqberci (2)
