Hi there
I'm looking for a few trade shows that would match our products and service but it has not been easy. We mainly manufacture pressure vessels and heat exchangers. I'm hoping that base on your expertise on Global Spec trade shows, you will share some info on what trade shows would be a good match for my company. Please take a look at all our products and give me some guidance. Thank you so much!!
High Pressure Heater
2. Low Pressure Heater
3. SH Double Bellows Heat Exchanger
4. SHV Double Bellows Displacement heat Exchanger
5. High Efficiency Intelligent
Exchange Unit
6. Thermal Web Heater
7. XMC Revolving Diaphragm De-aerator
8. Crane De-Aerator (Headless built-in type, horizontal de-aeration head type)
9. Inner Split Semi-displacement heat accumulation water heater
10. Inner Split Semi-displacement heat accumulation water heater
11. Closed-circuit cooler
12. Intermittent blowdown expansion tank, continuous blowdown expansion tank, drainage expansion tank, boiler starting expansion tank.
13. NZG series bad type automatic water supply unit, NZP series floor fixed expansion tank
14. Plate-type heat exchanger (detachable type)
15. PCW unit
16. Fully welded plate-type heat exchanger
17. GHT series lamella heat exchanger
18. Fume waste heat fully welded plate-type heat exchanger
19. ZJZ series shaft top heating unit
20. Fume waste heat exchanger
21. Compressed air cooling and dehumidifying system
22. AC low voltage complete power transmission/distribution and automatic control system
23. Deep Well cooling system
24. Unclear power plant conventional island pressure vessels and heat exchangers
25. Water treatment engineering and products.
