Previous in Forum: Calculating the Required Power for a Pump   Next in Forum: Rated RPM vs Maximum RPM
16 comments
Tolerance for Bearing and Shafts
05/20/2009 9:07 AM
I am designing a new shaft to suit our application in our compressors.
The shaft is a solid m.s. shaft and the dia of the shaft is 45mm.
The bearing we have choosen is SKF ( BALL BEARING - 1210EKTN9 ) WITH ADAPTER SLEEVE H210 .
This bearing is for a 45mm dia .
However i need to know to what tolerance I need to machine this shaft to suit this bearing.
can you kindly advise me in choosing the tolerance to machine this shaft ( I need to know the upperlimit and lower limit ) to machine this shaft.
Kindly please advice or from where can I find the deatils
Design Engineer - Engineering
Good Answers: 15
Re: tolerance for bearing and shafts
05/20/2009 9:36 AM
Quite often the bearing manufacturer will have recommendations for the clearances needed for the shaft.
Additionally I find the information in my machinery's handbook. ( A common american reference book) Look under "fits"
Do you want the shaft to slide into the bearing?
Are you heating the bearing up and then inserting the shaft?
Are you having a key or setscrews hold the bearing to the shaft?
downhill slide to 112 (damn memor.)
05/20/2009 9:49 AM
Bearing is not heated , hence I want the shaft to slide in the bearing.
Good Answers: 143
05/20/2009 10:52 AM
If it were mine, I'd call SKF. Otherwise, I'd use +0/-0.062mm.
05/20/2009 11:40 AM
Good Answers: 266
05/20/2009 1:01 PM
Re: Tolerance for Bearing and Shafts
05/20/2009 1:30 PM
05/20/2009 7:53 PM
Definitely, consult your bearing manufacture (SKF) about the requirements always. They have all those stuff mentioned in catalogs. The use of a different tolerance, although may be right, could lead you to loose any warranty is problems occurr. Also, as you're using a mounting bushing/sleeve, the sleeve may have its requirements too. I used to have such catalog with me, but I'm sorry to say that I just cannot find it now... its old, and I don't have electronic copies.
Humm... suspicious you are...
Good Answers: 103
05/20/2009 9:49 PM
This is a bearing with taper sleeve (1:12 or 1:30 split types with lock nut?)
Here the bearing fits are decided through pre-loading of the sleeve by locknut tightening.
The usual tolerances maintained in these cases are h6 or at the extreme h7
for 45mm this is +00/-16μ or +00/-25μ)
our shafta are larger >300mm dia, however the same principle apply.
05/21/2009 12:42 AM
All the required data is included in the technical section of the SKF catalog or any other bearing manufacturer catalog.
05/21/2009 12:52 AM
The bearing fit is dcided by various factors, such as application,clearance of the rolling elements (C3,C4 etc.). I beleive the shaft size shoudl be 45.015 to 45.030mm
Alterntively,Go the SKF site,fit selection
12/22/2010 12:59 PM
sorry i think always shaft size will be lees than nominal size
05/21/2009 2:31 AM
The Design Engineering......if you grab your machinist handbook or your mechanical drafting book they have limits and fits tables in them. You will need to select a type of fit them it will give you a upper and lower limit for both the bore and shaft.
If you dont have these books drop us a line via our website at http://www.alnoproducservices.com.au and i can look it up for you
Anthony
05/21/2009 5:55 AM
just hammer 45 O.D. shaft into 45 I.D. bearing. i always does and it works
05/22/2009 9:12 AM
What industry are you working for? I assume it is not aerospace!! When you say "45 O.D. shaft into 45 I.D. bearing" what is the actual dimension of the shaft? are you checking it all? How do you know it is not 45.5 or 44.5 for example?
05/22/2009 8:57 AM
If shaft to be rotates without slip with bearing inner race & outer race to be fixed in bearing housing; then transition fit for shaft with inner race & close location fit for outer race with housing bore. Vice-a-vice for reverse case.Pls.find the respective machining tolerances from ISO std. tolerance tables.
12/23/2010 3:31 AM
One of the bearing races(either outer or inner race) should have transition fit like H7m5 or H7k6 (ISO standard) & the other one should have close running fit as H7h6 of ISO; with the respective mating part i.e.shaft with inner race & bearing housing with outer race. This works well with non fluctuating, light or medium load conditions. For heavy duty fluctuating loads, ISO suggests to go for srink fits by heating the bearing in suitable oil media for 25-40 minutes & assy. in hot condition. you may refer to ISO or BIS standard, reprinted in machinery hand book or PSG design data book for the same. best luck. sanjay
Register to Reply 16 comments
Anonymous Poster (5); bhrescobar (1); chipbusters (1); ddk (1); israelkk (2); ozzb (1); sanup (1); sb (1); TVP45 (1); woodygb (2)
