Previous in Forum: Cars and Politics   Next in Forum: composition of ceramic clutch button
12 comments
2003 Hyndai Santa Fe - Pushing the Accelerator Makes a Rattling Noise
05/20/2009 10:50 AM
Hello,
I have a Hyundai Santa Fe 2003. I have had both coil Packs replaced with brand new spark plugs, a new timing belt, fuel induction service and injector cleaning, tranny flush, and regular oil changes. I only fill up with the best gas. she's been babied. I am getting an engine light that says it is an evap problem. Recently it was jerking when I was idling, which we found to be a bad coil pack. After another fuel induction service, the engine light came on a week later again to show once again that it was an evap problem. I have an inhouse fuel filter/pump so unless I drop the tank, I cannot get it replaced. The motor mount is fine. Does anyone know what else could be causing the metal rattling noise when I step on my accelerator? it sounds like I have tin cans rattling under my hood. The car doesn't want to go up hill or gain any power unless I push the accelerator all the way down and redline the car. (which of course, I am hesitant to do.) This rattling is driving me crazy. Please help.
Re: pushing the accelerator makes rattling noise
05/20/2009 12:52 PM
It sounds like your describing pre-detonation. Try a different octane fuel, or have it retimed.
Re: 2003 Hyndai Santa Fe - Pushing the Accelerator Makes a Rattling Noise
05/20/2009 4:26 PM
Are you sure that the check engine light is an evap code? May be a "lean" code? It sounds like it might be "leaning out" and "lean popping". Evap codes are most commonly a bad or loose gas cap, leaking evap canister or hose. Rarely are they because of a fuel pump problem, although I did have a leaking gas tank cause evap codes once. Have the codes checked again and let us know what they are.
ASE certified in engine mechanical, electrical and performance.If you think the comments are good, rate them so.
05/20/2009 4:29 PM
I am bringing it in on Thursday again. I will have them recheck the code and get back to you. thanks:)
Hobbies - Car Customizing - New Member
Good Answers: 11
05/20/2009 11:41 PM
are they charging you to learn how to fix it?
sounds like they are fixing results, not causes.
05/20/2009 11:44 PM
One of you exhaust mounting bolts might be loose or missing thus the rattle. The other problem might be the catalytic burner coming apart and partially plugging the exhaust.
05/21/2009 8:23 AM
Is that something i can see under the car near the exhaust pipe? I am not sure where the mounting bolts are. Is the catalytic burner something I can see? You're right, they are definitely just fixing the results of the main problem. But no one else has the right scanning tools to fix the dang thing.
05/21/2009 8:37 AM
Any vehicle sold in the USA from 1996 on must be OBD II compliant. Autozone will scan OBD II vehicles for free. Find out exactly what codes are present and let us know. Then we may be able to help you find the "root cause". Catalytic converters can cause a loss of power and a rattling noise. The easy way to check this is to drive the vehicle until you have the problem. Then pull over in a safe spot and look under the vehicle toward the center and see if you see "something" glowing "cherry red". If you do, you have a catalytic converter problem. But, it sounds to me more like a lean condition, which could be a fuel flow problem, but more likely an air leak in the induction system.
05/21/2009 1:07 PM
No!!! The catalytic burner broken pieces are plugging itself; eventually the motor will have no power; it will only be able to idle, simply because the exhaust gases can not escape. Too much back pressure. You will have to be towed in.
05/21/2009 1:24 PM
Something loose between the exhaust manifold and the burner.
05/28/2009 12:54 PM
The noise --if fuel knock-- can be caused by ignition timing incorrectly set; coolant temperature to high; EGR valve plugged (will usually set a check engine code). Too little ERG will often cause engine detonation knocking as you describe.
If the noise is not from inside the engine, but external, it can be a loose heat shield, a failing catalytic convertor--loose baffel inside- a failing exhaust pipe (some are double walled to keep exhaust hotter going to catalytic muffler.)
'Knocking is a description that applies to many causes. Any further description helps
Keith E Bowers, PMP
05/28/2009 1:16 PM
I took it to the dealer who said that the check engine light and diagnostic revealed a tiny leak just above the gas tank. He said it was harmless. the rattling that sounded like tin cans when I push on the accelerator was aparently not anything to worry about as he dubbed this noise,"normal for Hyundai Santa Fe's". I have been driving this car for three years and it is NOT normal. he says that nothing else is coming up on the diagnostic and said to bring it back whenever I have more problems. So much for trying to catch the problem before it got too bad. Guess I have to wait for it to break down first.
07/07/2010 10:56 PM
A guy at work had the same rattle and power loss at 50,000 miles and it was a clogged cat.
Register to Reply 12 comments
Anonymous Poster (1); Erich (3); GunnyW (2); Keith E Bowers (1); Kilowatt0 (1); trcymre (3); Yosemit3 (1)
You might be interested in: Fuel Cells, Fuel Testers, Induction Heaters
