Previous in Forum: Most simple, but essential question   Next in Forum: Leaf Blower on a Yatch - WATCH THIS
Cogeneration by Carnot
05/23/2009 6:13 PM
From a translation of "Reflections on the Motive Power of Fire", of Carnot by R.H. Thurston:
""Perhaps in low temperatures steam may be more convenient. We might conceive even the possibility of making the same heat act successively upon air and vapor of water. It would be only necessary that the air should have, after its use, an elevated temperature, and instead of throwing it out immediately into the atmosphere, to make it envelop a steam-boiler, as if it issued directly from a furnace"
"This kind of loss is found in all steam-engines. In fact, the water destined to feed the boiler is always cooler than the water which it already contains. There occurs between them a useless re-establishment of equilibrium of caloric. We are easily convinced, a posteriori, that this re-establishment of equilibrium causes a loss of motive power if we reflect that it would have been possible to previously heat the feed-water by using it as condensing-water in a small accessory engine, when the steam drawn from the large boiler might have been used, and where the condensation might be produced at a temperature intermediate between that of the boiler and that of the principal condenser. The power produced by the small engine would have cost no loss of heat, since all that which had been used would have returned into the boiler with the water of condensation"
"Simplicity is the ultimate sophistication" Leonardo da Vinci
Good Answers: 143
Re: Cogeneration by Carnot
05/23/2009 7:19 PM
