I'm designing a unique compound steam engine, and I need to calculate the horsepower and torque output. The only formulas I can find are for calculating power and tractive effort for steam locomotives, which isn't what I'm building. If they exist in standard units (horsepower, foot pounds, psi, etc.) that would help, since that's what I'm used to.
I'm trying to figure it out the "long way" - calculate the force on each piston, figure the average over 180 degrees of crank rotation, add up all the pistons, then figure torque based on the crank throw as a lever arm- but this is a pain converting into metric units and creating my own equations. Plus the unique configuration is giving me fits, since the piston forces vary greatly depending on whether the engine is running "simple" or with expansion.
If anybody is bored and feeling generous, let me know and I will supply the data.
