Previous in Forum: Ideal wall thicknesses for a honeycombed part made of Porcelain   Next in Forum: solid when dry soft when wet???
drum dryer
05/25/2009 11:44 AM
hi all
i need a short video that describe the drum dryer process
thanks a lot
Re: drum dryer
05/25/2009 2:00 PM
What are you drying?
Re: drum dryer
05/25/2009 2:21 PM
i need it in general
and i want to know why they use applicator roller?
Re: drum dryer
05/25/2009 2:24 PM
Sorry, can't help you.
Re: drum dryer
05/25/2009 3:30 PM
thanks
Good Answers: 101
Re: drum dryer
05/26/2009 1:54 AM
Re: drum dryer
05/26/2009 9:02 AM
what is the difference between Atmospheric double drum dryer, Atmospheric single drum dryer and Atmospheric twin drum dryers?
and what is the advantage and disadvantage of each type?
Register to Reply 6 comments
DVader1000 (1); lyn (2); Omar Badros (3)
You might be interested in: Process Dryers , Drum Pulleys, Drum Heaters
