Previous in Forum: How to Test Underground LV and HV Cables   Next in Forum: English is a Crazy Language
Propagation of Heat from the Sun
05/25/2009 11:25 PM
when we fly on high altitudes ,the outside temprature is minus degrees, the sunlights passes through this high altitudes first to reach the earth as at the same time earth is hotter,how does it happen?
Good Answers: 103
Re: propogation of heat from sun
05/26/2009 7:57 AM
Th heat of the sun (the radiation) is absorbed by?
What is the densiry of that absorber as you go away and away from the earth's gravity?
What is the temperature at the pure vacuum?
You are measuring the temperature of the sorrounding. So if you pause over these questions, the answer will be clear.
Reply to Forum Thread
You might be interested in: Trackballs, DSP Boards, Ring Gages
