Previous in Forum: Bug Zappers   Next in Forum: Current Density
Stator Ring
05/26/2009 2:10 AM
Hello everyone
I am trying to figure out where to find a stator ring. I have tried hobby stores, Grainger, ACE, and several other home improvement and electronics stores and I cannot find it. So does anyone know where I might be able to find a stator ring?
Here is the kind of ring I am trying to find:
Thanks everyone! I really appreciate any help anyone can give. Thanks!
Stephen
Good Answers: 21
Re: Stator ring
05/26/2009 2:30 AM
Find a local motor rewind shop. If they don't have, or can't make what you need, then they should be able to point you off in the right direction of suppliers.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
Re: Stator Ring
05/27/2009 12:34 AM
Give a look at snowmachines or motorcycle engines. They are achiving 40 amps at 12 volts
Re: Stator Ring
05/27/2009 2:08 AM
If it's big enough, you can find one at a motor refurb shop. Such as REMCO in Alcoa, Tn. If not, will probably have to toss it. Comes down to time, effor and returns. Most small motors cost so much to refurb compared to replacement that more often than not its just swap and toss unless some effort to salvage scrap metal.
Re: Stator Ring
05/27/2009 8:50 AM
If it's for experimental use, buy a motor and disassemble it, it ain't matter if it's working or just junk.
Re: Stator Ring
05/27/2009 8:57 AM
Re: Stator Ring
05/28/2009 12:04 AM
vcr
Register to Reply 6 comments
Anonymous Poster (3); DGCYS (1); heatrate10 (1); Switchman (1)
You might be interested in: Rotor-Stator Mixers, Metal Ring Seals, V-ring Seals
